Home Forums Products Stompboxes Help! Space Reply To: Help! Space
#161684
bohan
    Nick meant all cables (EXP, MIDI, USB) removed.
    It could be the ribbon cable that connects the mainboard and UI board in the pedal is loose. You may try to open up the pedal and replug the ribbon cable tight if you think you are capable of doing that. You should email support@eventide.com for more details
