Home Forums Products Stompboxes H9 Max lowering input Reply To: H9 Max lowering input
#161745
    I think you need to read the UM more carefully (make sure you have the latest version). What you are describing is input and output swell, not an input gain setting. A swell is where level can be controlled by the EXP pedal (or HOTKNOB), usually on a preset by preset basis. It works as described in the UM.
    The H9 does not have a way to reduce input gain, and may be overloaded if you drive it with a hot line signal – the only way to fix this is with an external pad or other gain control. The INGAIN control is intended to increase (only) the input gain to help with a low output guitar.
