Home › Forums › Products › Stompboxes › H9 Max lowering input › Reply To: H9 Max lowering input
#161774
bohan
    Looking at the UM https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/H9-UserGuide.pdf
    What you described above is from the “Setting Output Level” section.
    This is what’s under “Setting Input Level/Peak and Signal LEDs”:
    Adjust the H9’s input level for best audio performance. The red Peak LED indicates that the input signal level is close to clipping. Occasional flashing is OK. If the Peak LED is lit solidly, reduce the input level either by reducing the signal level fed to the H9 or by setting the H9’s input gain to a lower value. The green Signal Present LED shows signal present (40dB below clipping). Input Level is the same for all presets, and is found on the System Menu.
    • Press and hold the HOTKNOB button and Right Footswitch simultaneously for a few seconds to enter System Mode.
    • Turn the Knob until [UTILITY] is displayed.
    • Momentarily press the HOTKNOB button.
    • Turn the Knob until [INGAIN] is displayed.
    • Turn the Knob to adjust the gain between 0dB and +18dB.
    • Press and hold the HOTKNOB button and Right Footswitch simultaneously for a few seconds to exit System Mode.
