Home › Forums › Products › Stompboxes › H9 Hotswitch Momentary/Latch › Reply To: H9 Hotswitch Momentary/Latch
#161784
BlakeWilder
    Thanks for the ultra-fast response!!
    Yes, I tried that too today but unfortunately it seems that when using the expression trick it also applies to all algorithms…I use the H9 with a third party three way switch, Hotknob is the middle one. So you can set the middle switch only either to momentary or latch generally.Would be cool, if it was possible to do this per algorithm. But that’s ok since I want to get another H9 🙂
    Thanks again!
    Greetz,
    Blake
