Home › Forums › Products › Stompboxes › Using H9 as a volume pedal? › Reply To: Using H9 as a volume pedal?
February 2, 2022 at 3:04 am
#161935
Can anybody please check it with their expression pedal please? I want to know if it is a bug with the input/output volume thing or if the fault is on my side. I have tested with two expression pedals, only H9 and guitar, no other pedals in between. With or without H9 attached doesn’t make a difference.
I have tested this and found that there is some signal still preset even when the H9 displays a value of zero on the display for the expression range. I have made our team aware. Thank you for your patience, as our team returns to post-holiday operation.
Any news on this Joe?
