Home Forums Products Stompboxes Midi Connection with Alexander Pedals Reply To: Midi Connection with Alexander Pedals
#162688
    Given your serial number, you don’t have the above mentioned problem.
    If your unit is still under warranty, you could send it in to be checked.
    But, be aware that there are any number of issues that could cause this sort of problem.
    Most commonly, bad cables and grounding, or incorrect configuration.
