Home › Forums › Products › Stompboxes › Micropitch- Delay Knob Scales › Reply To: Micropitch- Delay Knob Scales
March 7, 2022 at 2:58 pm
#162714
Hello aewan86,
The Delay knobs are tapered in such a way to make it easier to access lower delay times through a greater portion of the range. But to answer your question more directly, the following positions render these delay times:
CCW = 0 ms
9 o’clock = 55 ms
12 o’clock = 300 ms
3 o’clock = 1400 ms
CW = 3000 ms
Keep in mind, these times are for when MicroPitch Delay is set to “Time” tap mode. When set to “Tempo,” the delay knobs will access subdivisions spread along the range of the knobs and the tap time will be dependent on a predetermined BPM.
