Home Forums Products Stompboxes h9: AUX sw – program change question Reply To: h9: AUX sw – program change question
#162724
luedmo
    hi Joe
    Thanks for your help on this! We are so close, but…
    The h9-3 does change but it then jams up (solved by unplugging the MIDI cable or tap-tapping on the presets button).
    I’ve tried everything I can, even separated the TIP & RING on the FS3X footswitch, played about with XMT.MAP
    fwiw – one H9 reacts slightly better being h9-3 in the MIDI chain then the other
    Below are my settings, maybe you can see what I am doing wrong?
    I see that there is a LST and NXT in RCV.MAP – might that have any bearing on it all
    Best,
    :L
    h91
    AUX SW:
    – NXT : RING
    – LST : TIP
    RCV CH : 10
    XMT CH : 11
    RCV.CTL
    – NXT : OFF
    – LST : OFF
    XMT CC
    – TIP : cc# 97 (dec)
    – RNG : cc# 96 (inc)
    – T+R : off
    RCV.MAP – all PGs offset +1 apart from
    – 121 : LST (irrelevant?)
    – 122 : NXT (irrelevant?)
    XMT.MAP – all offset -1
    CTL.XMT : ON
    PGM.XMT : ON
    OUTPUT : MERGE
    h92
    AUX SW: DISABLED
    RCV CH : 11
    XMT CH : 12
    RCV.CTL
    – NXT : cc# 96
    – LST : cc# 97
    XMT CC
    – T+R : off
    CTL.XMT : ON
    PGM.XMT : ON
    OUTPUT : MERGE.
    H9-3
    AUX SW: DISABLED
    RCV CH: 12
    XMT CH : 12
    RCV.CTL
    – NXT : cc# 96
    – LST : cc# 97
    XMT CC
    – TIP : OFF
    – RNG : OFF
    – T+R : OFF
    CTL.XMT : ON
    PGM.XMT : ON
    OUTPUT : MERGE.
