Home › Forums › Products › Plug-Ins › Split EQ Latency › Reply To: Split EQ Latency
March 14, 2022 at 5:13 pm
#162822
Can you please let me know what buffer size you are using (it should be as low as possible to reduced latency while tracking without overloading your CPU). You should also have both “Delay Compensation” and “Reduced Latency When Monitoring” enabled in Live’s settings. I was able to reproduce your issue when “Reduced Latency When Monitoring” was disabled, but enabling this setting fixed this for me. Let me know if that helps.
