Home Forums Products Plug-Ins Split EQ Latency Reply To: Split EQ Latency
#162823
salvodaze
Hi, thank you for the reply.
I recorded these at 128 buffer size which is what I usually use for tracking.
<p style=”text-align: center;”>As for the settings, I already tried enabling Reduced Latency When Monitoring which like you say should negate this issue but sadly it didn’t change anything. I haven’t played around with Delay Compensation though, I will give it a try. The strange thing is SplitEQ causing this latency even when off or on another track and Live does not report this added latency on the audio preferences tab. As long as SplitEQ is somewhere in the project, I get this added latency on the armed channel. I will check the Delay Compensation and get back to you. Thanks!</p>
