Home › Forums › Products › Stompboxes › Expression Pedal for Eventide Blackhole Pedal › Reply To: Expression Pedal for Eventide Blackhole Pedal
March 19, 2022 at 3:11 pm
#162907
hi Joe
“An additional input allows an external TS momentary aux switch to be used in parallel with the internal switch if required.”
This expression pedal look nice! And it seems a user can even have a TS switch in parallel. Sounds great, but how would that work with 3 H9s chained together? On different MIDI channels, or the same – is there an ideal setup you can suggest please
Thanks as always
:L
