Home › Forums › Products › Stompboxes › Midi expression pedal with H9 toggle Active On/Off › Reply To: Midi expression pedal with H9 toggle Active On/Off
#163108
posarelli
    Yes it’s possible an I used before on a Line6 M5:
    – PC 2 for recalling wah
    – CC#11 On/Off pedal (0/63 bypass, 64/127 On) on a midi action mapped on expression pedal (you need to limit pedal from 63 on heel)
    – CC#01 Expression pedal on another midi action mapped on expression pedal
    Es-8 can send 5 multiple midi signal at the same time.
    I was wondering if there’s a way to do same thing on a much more complex and versatile instrument line H9.
    CC for wah it’s ok, but i need to engage the effect (or pedal) when I engage the expression pedal.
    If I enter the preset and the q-wah is active it will be a problem, but if is not active click the pedal and use wah is not a viable solution live, is complicated and prone to errors in a stage situation…
    Thanks…!
