Home Forums Products Stompboxes Replacing MicroPitch Pedal for H9 Reply To: Replacing MicroPitch Pedal for H9
#163436
joecozzi
    An H9 Max can most definitely do what you want to do using the MicroPitch algorithm. Of course, the potentiometers on the dedicated pedal will always render slightly different results at the same position, so you will need to tweak the H9 settings to exactly match the MPD pedal. The main differences between the MPD pedal and the H9 version are that we added two more modulation types – positive and negative envelopes; we also added an extra second of delay time to the voices of the MPD pedal. Neither of these changes influence the classic MicroPitch sound you’re using.
