Home Forums Products Stompboxes H9 limitation of one effect at a time…. Reply To: H9 limitation of one effect at a time….
#163632
apalazzolo
    JavyMontoya …
    Search the manual for the term Hotswitch.  It is found in all Space algos (11 of them) and H9 algos (11 of them).   That and the exp ped can be very powerful tools for changing effects/sounds in real time.  The exp ped can morph between effects (within one algo) in real time. The Hotswitch can jump between effects (within one algo) in real time.  The changes can be either simple/subtle or quite dramatic.   See my list above for examples of the various effects within each of several algos.
    If you think about it, these features and the control app operate very similar to MIDI but within the H9.  Spinning knobs on the control app is like an intuitive way to program MIDI, but in the H9 you are programming the Hotswitch and/or exp ped instead of a MIDI controller.
