Home › Forums › Products › Stompboxes › H9 limitation of one effect at a time…. › Reply To: H9 limitation of one effect at a time….
#163667
Bodde
    “Plus, in 22 of the 52 algos, one can switch between the effect combinations (in real time with no glitch or lag) with a footswitch (called the Hotswitch).”
    can you explain? Not sure how to do this. Can you give an example?
    What I find limiting in the H9 is that you cannot go up and down in presets with footswitch the pedal itself.  Say you want switch from preset 11 to 12 for the chorus and then back to 11 for the second verse or so. This is very impractical to do on the pedal itself as far as I know. If someone has on idea how to this without a midi pedal or additional switch let me know! Switching on the unit itself is very cumbersome and slow
    It would be much more practical if you could switch up with the right footswitch and down with left. I don’t think this is possible?
