Home Forums Products Stompboxes Scale Intervals pitchfactor [ENIG]-Enigmatic, [NPLT]-Neapolitan, [HUNG]-Hungaria Reply To: Scale Intervals pitchfactor [ENIG]-Enigmatic, [NPLT]-Neapolitan, [HUNG]-Hungaria
#163765
    I don’t know that the scale intervals are documented anywhere.  (I may have it in my own archives … somewhere).  But it’s easy enough to figure out, and even easier if you use MIDI.
    1. Select the Diatonic / QuadraVox algorithm, and a base Key to use.
    2. Choose a Scale to analyze.
    3. Turn the Mix value fully clockwise.
    4. Turn the PitchMix fully counter-clockwise.
    5. Play the tonic of the Key you selected.
    6. Scroll through the harmonic intervals using Pitch A.
    7. Switch to the next Scale and repeat the process.
