Scale Intervals pitchfactor [ENIG]-Enigmatic, [NPLT]-Neapolitan, [HUNG]-Hungaria
Home › Forums › Products › Stompboxes › Scale Intervals pitchfactor [ENIG]-Enigmatic, [NPLT]-Neapolitan, [HUNG]-Hungaria
    • #163764
      mikezur
        Hello, I would like to know what are the scale Intervals pitchfactor about [ENIG]-Enigmatic, [NPLT]-Neapolitan, [HUNG]-Hungarian.
        Because existing enigmatic major,  enigmatic minor,  and enigmatic 6 noted.
        Because existing Neapolitan Minor, and Neapolitan major.
        Because existing Hungarian minor, and Hungarian major
        Thanks a lot
        Michaël
      • #163765
          I don’t know that the scale intervals are documented anywhere.  (I may have it in my own archives … somewhere).  But it’s easy enough to figure out, and even easier if you use MIDI.
          1. Select the Diatonic / QuadraVox algorithm, and a base Key to use.
          2. Choose a Scale to analyze.
          3. Turn the Mix value fully clockwise.
          4. Turn the PitchMix fully counter-clockwise.
          5. Play the tonic of the Key you selected.
          6. Scroll through the harmonic intervals using Pitch A.
          7. Switch to the next Scale and repeat the process.
        • #163766
          mikezur
            Hello, and thanks a lot.
            <p style=”text-align: left;”>I don’t use Midi but I will try your solution, if  I suucced I will inform intervals.</p>
            Michaël
