Home Forums Products Stompboxes Using iOS version of H9 Control to assign expression pedal ranges Reply To: Using iOS version of H9 Control to assign expression pedal ranges
#163821
joecozzi
    To the left and right of the ribbon strip there are two buttons. Click the left one when you want to set your minimum point; after you’re done making your settings click it again. The right button is used to set your maximum point. Repeat the previous step. Now as you move your expression pedal or ribbon strip you will see you mappings react.
