Home › Forums › Products › Stompboxes › Tuner Mute using aux switch › Reply To: Tuner Mute using aux switch
#163917
snailspacejase
    Thank you for your reply.
    My signal chain is basic, it comes into the H9 via input 1 and out through output 1. No switchers or parallel paths.
    The tuner is set to Mute and cuts the signal completely when operated from the H9. When the Tuner is activated using an aux switch the signal is bypassed, but possibly attenuated slightly.
