Home › Forums › Products › Stompboxes › Tuner Mute using aux switch › Reply To: Tuner Mute using aux switch
June 1, 2022 at 4:23 am
#163918
I’ve sorted it.
I had set the ring of my aux plug for tuner. In the Aux menu the ring was also set to bypass. Once I changed bypass to — the problem was solved.
Thanks again for your reply.
