Home Forums Products Stompboxes H9 powers up to “no algorithm” Reply To: H9 powers up to “no algorithm”
#164189
frankistein
    Hello, I wanted to know why I have the same error, I have updated the software for windows both the h9 control and the pedal that is h9max, when I load my list everything is perfect, except that when I turn the unit off and on again the aux control is misconfigured, but the bad thing is that if I have set preset 1 to 18 (from the app and from the pedal itself), it stays at zero and reaches 0-99 when it didn’t happen before.
    I already tried the solution offered above to delete and reload and configure the factory but the error continues.
    Maybe downgrading to previous firmware 5.8.5 (1) will work fine? currently the version of h9 control is 4.0.1 and the pedal software is 5.9.1 (0)
    Thank you very much
    germanaws2@gmail.com
