Home Forums Products Stompboxes Micropitch delay help Reply To: Micropitch delay help
#164192
joecozzi
    Hello nrx313, the simplest solution is to back off on the Mix knob. This will allow the dry signal to emerge and lower the volume of the detuned voices. I would say starting out on the first preset and moving the Mix knob to the 12 o’clock position is a good start. After that, you can try reducing the amount of detune for each voice.
