Home › Forums › Products › Stompboxes › Midi expression pedal with H9 toggle Active On/Off › Reply To: Midi expression pedal with H9 toggle Active On/Off
July 9, 2022 at 7:05 pm
#164678
Hi, I try to achieve what you are talking about but it doesn’t work for me.
I must miss something, when you say:
« Then in 0/127 section I use range from 63 (means NOT active for the H9) and 127 (64/127 is ACTIVE status). »
I which h9 menu are you doing that ?
thanks for your help 👍
