Home › Forums › Products › Stompboxes › Smashing Pumpkins’ crunch modulated tone of the Machina era on H9? › Reply To: Smashing Pumpkins’ crunch modulated tone of the Machina era on H9?
Also, the verse (far less reverb and maybe no delay) and chorus (tons of reverb and delay) tones are very different. You can use the hotswitch in Spacetime to set up a second sound, and then toggle between the two for verses and chorus’. Note that the delay trails will not spillover. They will be cut short when switching to the second sound.
If you want the delay to spillover when toggling between two sounds (with an expression pedal controlling the ribbon controller) you need to use Pitchfuzz (sorry, no reverb but it does have a fuzz) or UltraTap (sorry, no chorus but slurm’d delay/reverb would be a good fit). I have attached two examples for you (modify them to taste). In PitchFuzz the bottom end of the range is 1.2 voices.
