Home › Forums › Products › Vsig and Preset Development › Phasor block – phase offset › Reply To: Phasor block – phase offset
July 14, 2022 at 12:09 pm
#164709
Hey Puppeteer,
It looks like that’s just a typo in the module documentation. The actual range of the parameter should be 0 – 360 degrees. When you click on the phasor module, and then click the phase_offset1 field in the right panel that pops up it should display the Minimum and Maximum values as 0 and 360 degrees respectively.
Sometimes our documentation has some typos or is out of date so if you’re ever in doubt about the parameter ranges the documentation is telling you, you can always check it against those Minimum and Maximum values.
Hope that helps.
~Woody
