Home Forums Products Stompboxes My H9 does not receive midi program change from my AX8 or my ES5 Reply To: My H9 does not receive midi program change from my AX8 or my ES5
#164729
    The MIDI output setting doesn’t play a role in interpreting the information the H9 is receiving. XMT does not block incoming messages. It only determines how the H9 will react when it does receive a message – will it retransmit or not. RCV.MAP could be a source of confusion if somehow all program changes are set the same for some reason. Might be worth checking out.
    Joe, you are absolutely correct.  For whatever reason, I have had that assumption locked in my head, ever since my 1st PitchFactor pedal.  Probably because I’ve never used the pedal(s) to XMT any messages.  I stand corrected.
