Home › Forums › Products › Rackmount › H3000 Bypass with MIDI message › Reply To: H3000 Bypass with MIDI message
July 27, 2022 at 4:19 pm
#164795
So the manual was corrrect and not the tech note…”
Basically, you converted the decimal CC value of 8196 to binary 14-bit
and then separate it into two separate 7+7 bit values (MSB/LSB)
8196 (dec) = 10000000000100 (binary)
MSB=1000000 (first 7 bits)
LSB=0000100 (last 7 bits)
convert 7-bit binary back to decimal values:
1000000=64
0000100=4
MESSAGE FORMAT:
CC: 99
MSB: 64 NRPN 7bit
CC: 98
LSB: 4 NRPN 7bit
CC: 6
MSB: 0 data value 7bit
CC: 38
LSB: 0/1 data value 7bit (bypass/non-bypass value)
Fun stuff… 🙂
