Home Forums Products Stompboxes H9 Hotswitch Reply To: H9 Hotswitch
#164852
BBok
    Hi, I have found the tap tempo will still work with the tempo on, using the following settings to paired H9’s.
    H9 One – MIDI Receive Channel – Off
    Assign MIDI CC Messages > Tap Tempo CC “x” – your choice of MIDI channel
    MIDI Clock No > No > Yes
    MIDI Output Mode > Transmit > Transmit
    H9 Two – MIDI Receive Channel “x”   (whatever Channel assigned on H9 One).
    Assign MIDI CC Messages > Tap Tempo CC “x” – match Receive channel
    MIDI Clock settings to  > Yes >  Yes >  No
    MIDI Output Mode  > Thru + MIDI clock  *** It didn’t work until I thought might as well try it – Eureka! – tap tempo worked with tempo on).
    Cheers!
    ChannelH9 One set as  “transmit” and the second one in receive, but only with Midi Thru/Clock
