Home Forums Products Stompboxes H9 Max and somewhere in time tone possible? Reply To: H9 Max and somewhere in time tone possible?
#164853
PRSGUY513
    Most the Pitch algorithms allow the ability to add delay and even modulation. I would play around with the different algorithms and see what you can achieve. The Micropitch algorithm is great to thicken things and add some modulation. Maybe switching to a different preset and use a modulation or delay algorithm would be better for other parts of the song. Most the algorithms give the ability to have other effects it’s just the full tweakability and pristine aspects of the sound is not as extensive as the different purpose algorithms. A second H9 is a huge step up into having super multi fx capabilities, but shouldn’t be necessary to get what you need for the song. I would probably go the multiple presets and some creative footwork. Play around and see what you can achieve. Have you checked out the newly reopened Preset exchange? There might be something there that could do the trick. Preset Exchange
