Reply To: Time for a Misha Thread
Home Forums Products Eurorack Modules Time for a Misha Thread Reply To: Time for a Misha Thread
#165101
The 4MS POD 32 is a good choice for a simple case for Misha. You can get the POD with a power supply installed already (you will also need to purchase a power adapter for the POD) – https://4mscompany.com/p.php?p=974
Note that Misha is a 28 HP module and this case gives you 32 HP of space. You could fill up the rest of the space with other small modules, or blank panels.
You will also need a TRS > DIN Type A adapter to connect to MIDI devices with DIN inputs – https://www.sweetwater.com/store/detail/0-COASTMidi–make-noise-0-coast-midi-cable-1-8-inch-trs-to-5-pin-midi?mrkgadid=1000000&mrkgcl=28&mrkgen=gdsa&mrkgbflag=0&mrkgcat=accessories&acctid=21700000001645388&dskeywordid=39700064887253108&lid=39700064887253108&ds_s_kwgid=58700007229425432&device=c&network=g&matchtype=&adpos=largenumber&locationid=9003597&creative=532125732701&targetid=aud-570170767352:dsa-1366322260300&campaignid=6730319014&awsearchcpc=1&gclid=Cj0KCQjw0oyYBhDGARIsAMZEuMt_TTc02uhbyQEaDLupZSjZV6R31u-XwZncMoocji7xIy3iVF3gdakaAkV9EALw_wcB&gclsrc=aw.ds
