Home Forums Products Stompboxes XFADE Away – 24 Preset List Reply To: XFADE Away – 24 Preset List
#165230
    Thanks.  I’ll dial that one (two) up when I get back in front of H9 Control.  There’s certainly some cross-channel panning going on in Undulator, but it doesn’t seem to be hard alternating L-R taps like in UltraTap.  I guess the documentation could be correct: two delays, but with each having an extra single slap / tap built in.
    Here’s the best way I’ve found to isolate the delay(s):
    • INTENSITY – ~midpoint 50 [MIX parameter] or 100 (no dry signal)
    • TYPE –  Feedback
    • DEPTH(s) – zero (defeat all other control parameters)
    • FEEDBACK – zero** (or 0-100 expression pedal).
    • ** Even at 0, there are two “phantom ghost” repeats, like a slight bleed through on FEEDBACK)
    I’m going to say 4 taps / 2+2 delays, with baked-in (fixed) modulation on each.  It sounds like string bows scraping out triplets.  Peaking LFO over panning & volume sent to each tap?  At any rate, that 3-againt-4 is adding the complexity to the otherwise fixed length of repeats.  And this is before you add any of the other AM, FM, & pitch modulations.
    Something else I stumbled upon:  Try toggling down to SLOW [SLOW/FAST switch].  Opens up a whole new ballgame by rescaling all of the variable modulations.  And if I recall correctly, the position is save in a preset.
