Reply To: H9 Power Issue
Home Forums Products Stompboxes H9 Power Issue Reply To: H9 Power Issue
#165531
LloydEmAll
joecozzi:
Thanks for the reply! When it wasn’t working, I tried a different outlet (that was working for another pedal) to no avail. I no longer have the factory power supply so I suppose I’ll have to buy one to test it although it’s a bit ridiculous to expect people to use wall bricks on pedalboards?
PRSGUYS513:
The Pedal Power 3+ is the most expensive power supply readily available in Canada, so I’m not sure how you expected that comment to be helpful or what magically overpriced power supply you’re referring to.
