Home Forums Products Stompboxes Input/Output “volume” via midi CC Reply To: Input/Output “volume” via midi CC
#165613
oortone
    OK thanks. Actually the midi CC stuff I fully understand, I’m a midi veteran it’s rather the signal flow of the H9 that was unclear to me.
    So let’s see if I understand correctly the order:
    – First input of the H9 (gain to AD I guess) is the one controlled from the menu “Input Gain and Level Meters” in H9 Control.
    – Second is the Input Volume that can be controlled by midi CC and can be assigned but not stored in a patch.
    – Third there’s the patch and each patch has an output volume that’s stored with the patch but can not be assigned to midi CC.
    – Finally there’s the output volume, midi assignable but not stored with patches.
    Is that correct?
