Home Forums Products Stompboxes Can I use 2 aux switches on the H9 for 2 functions? Reply To: Can I use 2 aux switches on the H9 for 2 functions?
#166108
joecozzi
    Does the mono signal coming from the H9 change with the 2nd output plugged in to the H9?
    You are correct. If have something connected to the second output, the pedal will only function in stereo. The only way H9 will output proper mono audio is if Output two is not connected.
