Home › Forums › Products › Eurorack Modules › MISHA CV range (IN) › Reply To: MISHA CV range (IN)
November 9, 2022 at 1:16 am
#166376
I’m pretty sure you can adjust the voltage output of the keystep via arturia’s control center software.
Or you can set input range on the MISHA using the setup menu.
Or you can just use MIDI OUT from the Keystep to midi in of MISHA and forgo CV all together…which may still require some setup on both ends to get whatever results you want.
