Home Forums Products Stompboxes H90 Global Wet/Dry to 100%? Reply To: H90 Global Wet/Dry to 100%?
#166631
joecozzi
    Hi soundsubs, that is correct. That’s the way kill dry works, it simply removes the dry signal from the mix. It is necessary to make adjustments based on your needs, so manually adjusting your presets’ Mix to 100% might be necessary. Because the H90 doesn’t know how you’re going to use it, it lets you decide how to manage levels.
