Home › Forums › Products › Stompboxes › H90 Control Instructions? › Reply To: H90 Control Instructions?
November 15, 2022 at 12:03 pm
#166730
Does the H90 allow you to control amp channels with the Suhr Micromidi without having to use the Morningstar? I see you added that in the after pic. I’m trying to figure out if I need to get a midi controller beyond what the H90 does.
I think the answer is yes. The H90 can transmit MIDI messages, so it seems this should work fine.
