Home › Forums › Products › Stompboxes › H90 questions › Reply To: H90 questions
November 15, 2022 at 9:06 pm
#166746
And here is a way to do that with reverb on the H9 or the H90 using the DualVerb algorithm (see attached screenshot). In this example, I basically turn reverb B off but you could obviously add a little reverb in there if you want. This only uses one of two preset slots of the H90 so you still have power to do something else there if you want.
Good luck!
