Home Forums Products Stompboxes H90 Power draw & routing Reply To: H90 Power draw & routing
#166805
joecozzi
    Just to confirm (as im a bit nervous about hitting the unit with 18v) – 2@ 9 volt, 400ma outputs combined with the Voodoo Lab current doubler https://voodoolab.com/product/current-doubler-adapter/ will work with the H90 and not damage the unit ? I am using the following https://www.sweetwater.com/store/detail/PedalPwrDig–voodoo-lab-pedal-power-digital-4-output-isolated-guitar-pedal-power-supply Utilising the two 9 volt 400ma outputs as described above. Thanks !
    You will be alright.
