Home Forums Products Stompboxes H90 Power draw & routing Reply To: H90 Power draw & routing
#166826
ed536m
    I have a cioks dc5 if I use the CIOKS 4022 Type 4 Stack Flex Power in the outs that have 300ma each would that be enough to power the H90? Two 12v at 400 ma each. thanks
    No. The stack flex cable is used to add the voltages of each outlet. The H90 cannot accept 18V or 24V.
    Ok thanks. Is it the cioks 8800 that doubles the ma? So if I used two 12v 300ma outlets with cioks 8800 will that then provide it 12v 600ma and would that be safe?
    thanks again
