Home › Forums › Products › Stompboxes › Timefactor + Space MIDI clocks › Reply To: Timefactor + Space MIDI clocks
November 22, 2022 at 8:17 am
#166926
If all you’re after is MIDI Clock sync, then you don’t have to be concerned about MIDI Channels, Program or Control Change system settings. Otherwise, it gets more involved. I’m sure Joe has some slick videos up on the subject, but here is the basic layout:
TimeFactor -> MIDI cable from OUT/THRU to Space MIDI IN
- System settings – MIDI:
- [OUTPUT] XMT
- MIDICLK OUT – ON
SPACE -> MIDI cable from OUT/THRU to 3rd Device MIDI IN (set device to receive MIDI Clock)
- [OUTPUT] THRU
- MIDICLK IN – ON
3rd device -> set device to receive MIDI Clock
