Home › Forums › Products › Stompboxes › Timefactor + Space MIDI clocks › Reply To: Timefactor + Space MIDI clocks
#166929
delorean666
    If all you’re after is MIDI Clock sync, then you don’t have to be concerned about MIDI Channels, Program or Control Change system settings. Otherwise, it gets more involved. I’m sure Joe has some slick videos up on the subject, but here is the basic layout: TimeFactor -> MIDI cable from OUT/THRU to Space MIDI IN
    • System settings – MIDI:
    • [OUTPUT] XMT
    • MIDICLK OUT – ON
    SPACE -> MIDI cable from OUT/THRU to 3rd Device MIDI IN (set device to receive MIDI Clock)
    • [OUTPUT] THRU
    • MIDICLK IN – ON
    3rd device -> set device to receive MIDI Clock
    Thanks, I’ve set it up like you wrote. This gets the clock correctly to the third device, but the Space freezes in the process and I can’t turn it on anymore.
    It only starts responding again when I unplug the MIDI cable.
