Home Forums Products Stompboxes H90 Power draw & routing Reply To: H90 Power draw & routing
#166990
joecozzi
    If the dip switch is ON for 12V functionality and you use a current doubling cable, you’ll achieve the minimum amount of power to turn the unit on. So, the answer to will it work is yes. However, at boot up, the H90 spikes to about 550mA. I am not familiar with that power supplies ability to handle that since this method would only top out at 500mA. I would search elsewhere.
