Home › Forums › Products › Stompboxes › Split: H90 Insert Feedback › Reply To: Split: H90 Insert Feedback
November 30, 2022 at 7:43 am
#167288
P.S: it may be good idea to check and reverse the role as well. Put pedal in insert 2 and put it on parallel path and then try insert 1 which has nothing in it and put it in pre-position and see if you get same results when investigating! 🙂
