Home › Forums › Products › Stompboxes › Split: H90 Insert Feedback › Reply To: Split: H90 Insert Feedback
November 30, 2022 at 11:34 am
#167312
This is normal behavior. Keep in mind that when you engage a parallel signal path you’re splitting the dry signal as well, so there’s two copies of the signal present. This is why the H90 gives you a couple of options to tailor your signal flow levels: you can run algorithms in Kill dry and/or you can adjust the Inserts Mix, send and return levels.
