Home › Forums › Products › Stompboxes › H90 CONTROL IDEAS (please forward this to developers) › Reply To: H90 CONTROL IDEAS (please forward this to developers)
Another minor idea maybe. So when adding inserts from the control app there’s just too many clicks that you have to do to add a insert to the end of the signal path. For instance on a series path you have to make 4 mouse clicks to get to the end of path and on parallel there’s 6 mouse clicks. Should be an option that allows us to click left < button and it starts at the end of the path. And if we were already at the end we should be able to continue to click > right button to bring us to the beginning instead of having to < back click all the time etc. The same limitation is also on the hardware. Let us freely go < left or right > without it stopping us. Just makes for a faster work flow
Oh wait, i totally forgot on control app you can click in the middle of the < and > and it brings down a drop box and you can choose the destination, so yes that does make it a bit easier, but still wouldn’t be bad idea to do what I said above and definitely do it for hardware since there’s no drop down for hardware obviously.
