Home › Forums › Products › Stompboxes › H90 CONTROL IDEAS (please forward this to developers) › Reply To: H90 CONTROL IDEAS (please forward this to developers)
#167406
brockstar
    Ok think I found another H90 control bug or hardware bug…
    At the bottom right on h90 control you have “parameter edit mode” when you’re on the parameter tab.
    When you click one of the prg / hs1 / hs2 / hs3 it works fine and shows up on hardware as well that they’re working together
    However when you click on the hardware hs1 / hs2 / hs3 it doesn’t show that on the H90 control editor.
    Not sure if that is by design or not but wanted to mention it.
