Home › Forums › Products › Stompboxes › H90 CONTROL IDEAS (please forward this to developers) › Reply To: H90 CONTROL IDEAS (please forward this to developers)
Ok think I found another H90 control bug or hardware bug… At the bottom right on h90 control you have “parameter edit mode” when you’re on the parameter tab. When you click one of the prg / hs1 / hs2 / hs3 it works fine and shows up on hardware as well that they’re working together However when you click on the hardware hs1 / hs2 / hs3 it doesn’t show that on the H90 control editor. Not sure if that is by design or not but wanted to mention it.
I was confused by this too. It is normal. IIRC it’s because the Control screen is in edit mode and the H90 is in performance mode (if you are performing, you are not editing).
Yeah but still don’t make sense that if you hit HS1 / HS2 / HS3 on the control app that it shows you doing that on the hardware, it should do the exact same thing from hardware to editor?
