Home › Forums › Products › Stompboxes › H90 CONTROL IDEAS (please forward this to developers) › Reply To: H90 CONTROL IDEAS (please forward this to developers)
December 5, 2022 at 12:18 pm
#167426
Ok 🙂 but what about the other issue I was explaining? Is it normal or no? Can you replicate it?
“At the bottom right on h90 control you have “parameter edit mode” when you’re on the parameter tab.
When you click one of the prg / hs1 / hs2 / hs3 it works fine and shows up on hardware as well that they’re working together
However when you click on the hardware hs1 / hs2 / hs3 it doesn’t show that on the H90 control editor.
Not sure if that is by design or not but wanted to mention it.”
