Home Forums Products Stompboxes H90 CONTROL IDEAS (please forward this to developers) Reply To: H90 CONTROL IDEAS (please forward this to developers)
#167427
    Engaging a Hotswitch is not the same thing as Hotswitch parameter edit mode.
    On the pedal UI, if you hold one of the P/A/B buttons from the Parameters edit page, this will enter the Hotswitch parameter edit mode on the pedal and the H90 Control parameter edit tabs will follow along. If you select a different HS tab from H90 Control, the pedal edit page will follow along as well.
    If you just engage a HS from the pedal you are not in parameter edit mode, therefore the H90 Control parameter edit tabs will not be selected.
